When I try to to run a spin cycle only it will make a couple of beeping sounds like it is starting the cycle, but it will stop at the door lock light coming on. It will do the same no matter which option or cycle chosen.
SOURCE: smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
SOURCE: TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin?
Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on?
Press START/PAUSE once. The door will unlock.
