Question about Frigidaire Refrigerators
How do I tighten door handle on frigidaire model jsi-26
Posted by Chris sayensopg on
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
Posted on Aug 14, 2015
5 Related Answers
benham
  • 125 Answers
SOURCE: Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Posted on Jan 08, 2008
Anonymous
SOURCE: loose handle on door
for GE profile french-door freezer door, pull right...
Posted on Oct 19, 2008
Anonymous
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
Anonymous
  • 220 Answers
SOURCE: Where can I download an owners manual for a
http://www.frigidaire.com/manuals.aspx
Posted on Sep 13, 2009
Anonymous
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Posted on Dec 30, 2009
How do you remove the handle to get to the screws to tighten the handle its very loose
Hello Martin;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on the upper inside wall of your fresh food section. So, I can not be accurate in regards to your unit.
1.) Inspect your handles. Are there 3/32" allen wrench screws at the top and bottom? If so back off the screws until the handle comes off. Then tighten the screw on the refrigerator door. Put handle back on the and tighten the 3/32" screws.
2.) No external screws - Then the handles are held on in a slip in slot fashion. Pull up on the door handle. This is going to take a little mussel. Remove the door handle. Tighten the screws on the door and the back of the handle. Slide handle back into place.
Mar 25, 2015 | Refrigerators
We have a 3 month old fridge and the handle is coming away from the fridge. There is a bolt under the handle which suits a 4mm allen key, but it does not seem to do anything if you tighten or loosten it. ...
The bolt on the handle tightens on a pin that comes through the door. If the tightening the screw on the handle and it still does not tighten then the pin has come loose inside the door. If the unit is only 3 months old I suggest contacting who you bought it from. It should be under warranty.
Feb 03, 2015 | Refrigerators
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle is loose on GE Monogram Model# ZFSB27DAG SS. How do I get thehandle tightened up? No steps have been taken to fix problem. Stirwin
handle secured by 4 stainless stand offs on each door correct?, i would look closley at the underneath of the standoffs should be a screw to tighten/loosen. . actually lookin at diagram theses are comlete doorskins wrapped around the door itself you might need to remove teh screws on top and bottom ofr door skins and tighten from behind s/s skin
Mar 04, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
429 people viewed this question
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
