SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
SOURCE: AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.([email protected])
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
SOURCE: how do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
