Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
How do I secure part (electric water heater thermostat) for Rheem 40 gal natural gas water heater?
Electric water heater thermostat for 10 year old 40 gallon water heater natural gas
Posted by mk_mayf on
janilly roswell
    New Friend:
  • 39 Answers
See our list of the best electric water heater for 2015. Read our best electric water heater reviews and tips for maximum performance without wasting time..
Posted on Dec 02, 2015
Gene Haynes
  • Rheem Master
  • 5,391 Answers
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 22, 2012 | Water Heaters
My water is not heating in my Rheem 40 gallon electric. I pushed the reset button, but when I turn off the breaker and then on again, I do not hear the elements heating up.
Electric water heater can be repaired by homeowner
If I understand correctly, water heater is producing no hot water.
Reset button clicks in, but still no heat.
Three initial things can be causing this:
1) No power to water heater. Test across top two screws on upper thermostat for 240V. Red and black wire are attached to these screws. Screws are marked 1 and 3. Upper thermostat is same that has reset button. If power tests 120 across screws, then breaker may be off on one leg. If no power, then start testing at breaker.
2) Upper thermostat is bad. Replace thermostat with generic upper thermostat available at hardware store.
3) Upper element is bad. Test and replace element using Rheem 4500 watt element available at hardware store. Image shown below. Look at label on side of tank for element wattage. Rheem puts 4500 watt elements into all their 240V electric water heaters.
If upper element is burned out the tank will not heat any water.
http://waterheatertimer.org/How-it-works.html
Rheem 4500Watt element
Upper thermostats are generic and interchangeable:
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
There is no hot water
Do you know were your hot water tank is?
How old is your hot water tank?
Is it a gas or electric hot water tank?
Aug 15, 2009 | Water Rheem MR40245 Marathon Electric ...
Not enough hot water
Makes you feel good to save some money right? Have a great day!
Apr 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
350 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
