My wii fit plus disc reads cant be read when inserted in to the wii
help please can it be fixed
Hi lyned1,
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Thanks for using Fixya.
Jan 28, 2011 |
Video Game Consoles & Games
