Question about Arcade Alley Alley Electronic Double Hoop
How do I assemble the home version?
It is a 2 hoop home version of the Arcade Alley electronic double hoop to hoop game. Can you help me out?
Posted by Myrna Barnes on
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
Need instruction manual
http://www.instructionsmanuals.com/
Feb 14, 2016 | Spalding Basketball Spalding NBA 66349...
How can I buy the parts for this product?
Go to Home depo or hard where store that sales plumbing pipes. Take one of the pipes with you and match the size to the L joints they have. Spray paint black to match and down. A whole lot cheaper then buying the original L joints.
Jul 24, 2014 | Harvard Double Shootout Arcade-Style...
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Apr 18, 2014 | Basketball
Score calibration
take it to the store or true it off and take the wire then put it back and then try
Dec 25, 2013 | Rhino Play Double Shootout Basketball Game
How to fix my basketball hoop
Your either going to have buy a new one which I'm sure you want to be a plan Z. With that said, your going to have to weld it at a position that is not adjustable or is possible weld and screw 2 sides where it can move at the broken angle
May 26, 2013 | Basketball
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Jan 28, 2013 | Basketball
Arcade Alley Alley Electronic Double Hoop Logo
398 people viewed this question
Top Arcade Basketball Experts
Anon
Tom Chichester
Meli Dragon
Meli Dragon
Are you an Arcade Basketball Expert? Answer questions, earn points and help others
