Fedders AED24E7F Wall/Window Air Conditioner Logo
Linda D. Griggs Posted on Jul 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats the right settings for the window air conditioner.
Its a Fedders built in 3 minute cooling delay windows air conditioner and heater i dont have the manual and i need to know the right tempature settings
william simpson
Level 3:
Genius:
  • Fedders Master 1,363 Answers
  • Posted on Jul 31, 2015
william simpson
Fedders Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
318127
Points
1636
I operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
I have a fedders window ac and only the serial number. how can I find out the age and the number of btu's?
How do I tell the age of a Fedders furnace or air conditioner from the serial number?
Although the Fedders brand is used for window units nowadays, this encoding only applies to when they manufactured unitary (split) systems years ago. The second letter of the serial number indicates the year of manufacture (from 1966 to 1977):
A = 1966 B = 1967 C = 1968
D = 1969 E = 1970 F = 1971
G = 1972 H = 1973 I = (not used)
J = 1974 K = 1975 L = 1976 M = 1977
An ancient Fedders unit we recently inspected had the serial number AH11877, indicating that it was manufactured in 1973. The home was built in 1973, which provided a secondary verification of the manufacture date indicated by the serial number
https://www.manualslib.com/brand/fedders/air-conditioner.html
Fedders 3 minute cooling delay. What does that do??? Should the air vent be CLOSE or OPEN??? If on fan only, what is the use???
It prevents the unit from short cycling and killing the compressor. The air vent brings in outside air to "refresh" the indoor air.
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • 0helpful
    2answers
    My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    The outdoor coil is plugged with ****....
    Here is a tip about troubleshooting your air conditioner...
    There are many things that can cause your air conditioner not to cool…
    Air Conditioner Trouble - Review the Possibilities
    heatman101
    2helpful
    Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
    you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
    2helpful
    2answers
    Need Owners MAnual
    Go to safemanuals.com and then to this link: http://safemanuals.com/user-guide-instructions-owner-manual/FEDDERS/A6Y12F2B-E-_E
    to get your manual. If its not the specific one, put in ur request and leave ur email. They will inform you the moment they find one.......sodeep
    1helpful
    Top Fedders Heating & Cooling Experts
    Jay Finke
    Jay Finke
    Mike Cairns
    Mike Cairns
    Aron
    Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
