SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
SOURCE: When engage the PTO switch, nothing happens.
Not knowing what mower you have from the information you have given; There are several possibilites; The ptop switch could be bad, the pto on the engine that engages the blades may be burned up or you can have a fuse or safety relay needs replacing. If you know your model number, you can go to www.precisionope.com and look at the diagrams and parts you will need.
Good Day.
Testimonial: "Thanks much!"
SOURCE: husqvarna riding lawn mower pto is not engaging?
when you dropped the deck did you knock off the pto electrical plug?
