Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson TV won't stay on
My emerson tv/dvd/vcr combo stays on for 15-20 seconds and then turns off. Good picture & sound for the 15-20 seconds then it turns off by itself. Repeats that problem each time you push the power button on the front of the set. What can the problem be?
Thanks,
[email protected]
Posted by channelcat on
  • 3 more comments
  • lilhotty Mar 02, 2008
    Tv stays on for about 10 sec and then turns off...what do I do. I cant try anything because it doesnt stay on long enough to trouble shoot.
  • Anonymous Apr 05, 2008
    I bought an emerson high def on the wall unit.It is less than two months old. All of a sudden it won't turn on only about 1/2 second What is going on. Ive unplugged it to reset it several times but no change. Im pissed off as it seems I am not alone with this problem.
  • Chrissi1982 Aug 31, 2008
    We had this TV given to us for our daughter's room. But everytime we turn the TV on it will stay on for about 15 seconds and then shut off all by itself. It's an older model but was told when our neighbor gave it to us that it worked. If anyone has a solutions please let me know.
  • leo_jennyful May 11, 2009
    my 32 in emerson ser l37722229,Ive had one year five month,you turn it on ane it shuts right back off,I see I'm not the only one that has that promblem,all I got to say for the price I payed it should be taken care of free of charge. this unite was bought at wal mark.
    Leo of Ticonderoga N.Y.
  • Anonymous Mar 12, 2014
    manual for emerson model 0902 tv/vcr combo
Anonymous
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Posted on Mar 16, 2008
Gregory Dodson
    New Friend:
I encountered this problem when I have a tape in the VRC player. The tape had gotten stuck in the player. Every time I powered to TV on it played for a few seconds and then turned off. Once I removed the tape from the VCR player the prower stayed on so if there is a tape in the VCR player remove it.
Posted on Jul 08, 2012
  • Mary
    Mary Apr 19, 2014
    The VCR tape is stuck in there.. how do you get it out?
Anonymous
Someone told me that the timing is off in the vcr and that they would have to rebuild the whole tv, which is more expensive than buying a new one. I saw on another site that someone has to leave a vhs tape in the vcr for the tv to work, I think that I am going to try that.
Posted on Jan 10, 2008
Anonymous
Making sure a vhs tape was in system fixed my on off problem
Posted on Aug 04, 2009
Anonymous
Check the fuse...
Posted on May 15, 2009
1helpful
[email protected] you have the universal remote code for emerson dvd vcr combo ewd2202
Hello
Unversal remote setup codes for Emerson DVD/VCR combo are:
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK
Emerson tv;vcr combo, have one for all remote, need code and instruction on setting up new remote
Hello
You haven't specified nothing about the model number or any other descriptions about your Emerson Combo or the remote control you wish to setup with it. Anyway, I hereby posts some codes for Emerson TV/VCR combo. Try with them.
0227 0233 0254 0264
0265 0266 0310 0325 [0039 0252]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
Direct Code Entry
OK.
Please inide code for tv emerson
Hello
You havent specified what type of Emerson combo is yours. Anyway I hereby posts some Emerson combo codes.
TV/VCR
0227 0233 0254 0264
.... 0265 0266 0310 0325 [0039 0252]
TV/DVD combo
0456
TV/VCR/DVD combo
0456 [0458 0227]
DVD/VCR combo
0456 [0458 0227
Direct Code Entry
2helpful
I need code for tv
Hello
Three digit universal remote code for emerson are:-
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit universal remote code for Emerson TV/vcr combo are:-
0456 [0458 0227]
Direct Code Entry
Also try these four digit codes for Emerson Tv also. There are so many codes for Emerson Tv.
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
1helpful
Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Innovage Universal Remote
My code light stays on...will not accept and buttons...any ideas
3helpful
3answers
Emerson
Try using 051. I just found it online, used it and it worked!!!
STANDBY BUTTON
call 1-800-256-2487 they will help (maybe)
17helpful
4answers
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
Top Emerson Televison & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
