With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
When the LED lights in green, press the Stop/Reset button 4 times
To Reset the newer Barricade Router, use the RESET button on the Router. It is found on the rear panel (except 7004ABR/7008ABR, where it is found in the front). It's a small pinhole blue button. Use a paperclip / pen / pencil to hold in. Reset can be done in following ways. If you find Power LED blinking, then it indicates a successful RESET......
Procedure 1 - Unplug all the cables except the power cord. While the Barricade is powered ON, Hold the RESET button for 30 seconds or as long as you find the Power LED blinks.
Procedure 2 - 1 - Unplug all the cables except the power cord. 2 - While the Barricade is powered ON, Hold the RESET button for 5 seconds. 3- While holding the RESET, turn OFF the power to the Router. 4- Continue to hold it for 5 seconds, then turn ON the power to the Router. 5- Wait for another 5 seconds and then release the RESET button.
Procedure 3 - 1 - Unplug all the cables except the power cord and Power ON the Router. 2 - Hold the RESET button for 3 seconds. 3 - Release the RESET button for 2 seconds. 4 - Continue Steps 2 and 3 for Four more times.
1. Reset the router by pressing the reset button of the router for 15 seconds while the power cord is plugged in and while the router is powered on. 2. Release Reset button after 15 seconds and unplug the power cord of the router then press the reset button again for 15 seconds. 3. After 15 seconds release the reset button and replug the power cord then press the reset button again for 15 seconds.
If this didn't work. 1. Plug the power cord to the router, and unplug it do this 7 times then reset for 15 seconds while it's unplugged and plug it back it and press the reset button for 15 seconds and release it. Try to check if there's any changes.
kindly follow this steps to fix the error
Reset manual "Ink Absorber Full" for pixma Steps by steps how to reset :
1. Turn off the printer but still connected to a power source 2. Press stop/reset button, and then press power button to restart 3. Press power again and then press twice the stop/reset button. 4. Press power & Stop/reset button together, to enter the repair status and power lights will be green, 5. Press stop/reset button 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset 6. Turn off the printer 7. Unplug the power cable. 8. Plug the power cable and then turn it on again.
Reset procedure 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
Following is the procedure to reset waste ink counter Canon Pixma MP145 :
Connected Printer to a Power source, Turn off the printer if printer on
With the Printer power off, press the Power button while press and hold Stop/Reset button.
When the Power led is light, press Stop/Reset button two times while pressing and holding the Power button.
When releasing the Power button and the Stop/Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
When the on/off lights in green, press the Stop/Reset button four times to reset wase ink counter. For other specified number pressed function listed in the table below. (Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange).
Unplug cable power from a power source.
LED
Function Remarks
0 time
Green
Power off
1 time
Orange
2 times
Green
EEPROM print
3 times
Orange
EEPROM reset
4 times
Green
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
