Question about U-Line Model: CO1175S01 Compact Refrigerator
Mini refirgerator stopped cooling, interior light
2 year old U-line mini refirgerator stopped cooling, interior light goes on
Posted by velaone on
Rich Wright
  • 286 Answers
If nothing is running but the light is on you might want to unplug the unit for about a minute. Then plug it in. If it starts up again then do nothing. It just had to be adjusted. If the display shows a er then it could have something wrong with the thermistors. If it shows 2 dashes then let me know and I can try to walk you thru a program to get you backup and running again. If 2 dashes you will have to get to the plug so pull the unit out.
Posted on Jul 12, 2009
3-year old mini freezer/refrigerator has stopped working.
Seems to be compressor not working kindly check your refrigerator thermostat setting or capacitor device worn out
Need to replace
Jul 12, 2016 | Frost Refrigerators
Our Amana refrigerator has stopped working. The compressor does not start and is cool to the touch. There are no clicking noises and no signs of life, no fan is running. The freezer and refirgerator are...
If you have power to the plug, then it is either the start capacitor, the start relay or the compressor. IIf it is the compressor it is a major expense, so you will decide how much you are willing to invest in an old one, before you buy a new one.
Jul 07, 2011 | Amana ARB2217CSL Bottom Freezer...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Stop working. stop running. where is the reset button? where is the overload?
It will be very diffilcult for even the most experienced technician to troubleshoot your refirgerator with so little information. No make and model number, no infor on how old it is...therefore start with the basics:
Verify it has power (does the interior light(s) come on?
If so, most refrigerators DO NOT have a reset button. The motor overloads reset when they cool off. If your unit has power and will not start after left alone (unplugged) for a few hours, then either the thermostat controls (most likely), a part of the thermostat controls (some controls use mutilple sensors and control relays), the overload on the compressor is bad or the compressor itself is bad. If the condenser fan runs but the compressor does not...I would suspect a problem with the compressor or it's electricals. If nothing starts except lights...I would suspect the temperature control. Good-luck.
Jan 09, 2010 | Refrigerators
GE Arctica Refrigerator suddenly stopped cooling. Motors are running, controls are responding, but interior of freezer and refirgerator section is not cooling down.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
U-Line Model: CO1175S01 Compact Refrigerator Logo
250 people viewed this question
Top U-Line Refrigerators Experts
Marvin
Marvin
Kardoc
Dale Copeland
Dale Copeland
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
