Computers & Internet Logo
A
Anonymous Posted on Jul 29, 2015
What is f6 and how to fix it - Computers & Internet
1helpful
1997 Honda Valkyrie 1500 f6. How do you fix slipping clutch?
Check the adjustment at the clutch push rod.. If that doesn't fix it, you replace the clutch plates and springs. Check out all the videos. It seems to be a known issue.
https://www.google.com/search?q=1997+Honda+Valkyrie+1500+f6.+How+do+you+fix+slipping+clutch
1helpful
F6 error code of lg split ac
http://www.fixya.com/support/t4357840-onida_split_ac_displays_f5_f6_error
People have answered this question on here so thought this would help.
F6 error is related with the indoor blower motor check the return signal wire of motor with the small connector and fix it properly.
3helpful
2answers
F6 error on Hitachi washing machine Sk 120KJS
If your washing machine indicates fb or F6.. here's what i always do..
Make sure your washing machine has connected to the power socket..
To switch on your washing machine
Hold the power button of the washing machine and at the same time switch on the power socket..
Voila! It works!
Do take note that by doing that it does not fix your washing machine but it helps to overcome this issue..
1helpful
Im getting a f6 code on my digital control topside pack. what is this and how can i fix it
F6 typically doesnt indicate an error. This is usually a programming code that tells you spa to filter every 12 hours.
If it is a FLo code that just looks like an F6, then you need to either replace the filter, replace the flow switch , or make sure the pump is pushing enough water.
How do i fix f6
Stk 470-040 ic is blown and need to be replaced at service cntr.
Mine keeps giving me a F6 error, any ideas
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
F6 code// will not finish spin cycle every time?
136helpful
28answers
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Grand Canyon Tech
Grand Canyon Tech
