SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
SOURCE: Message error 6A80
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: service error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Error message 6000: Printer error has occurred.
Visit to the given link for operational manual... http://www.retrevo.com/support/Canon-MP620-Multifunction-Printers-manual/id/23007ci369/t/2/
.... Hope this has helped you...
Thanks...
