The model number is actually BFHS2611LM0. The handles have keyhole openings that fit over the pair of screws (near the top and bottom of the handle) on the outside of the doors. Try pushing the right side handle forward and down to lock it back onto those screws. If that doesn't solve the problem, push the handle up and then lift it off the screws. Then tighten the screws a bit (or replace them if they have stripped threads). Then replace the handle over the screws and push the handle down. Do not overtighten the screws; that can damage the door components. The manuals is available from Frigidaire's support site: http://b2b.frigidaire.com/support/manuals.asp . The support page for your refrigerator is here: http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=BFHS2611LM0&User=&Search=Search . The parts diagram shows how the handles are attached; it's the last link on the support page.
I hope this helps.
(please replace the door seal properly to ensure that your refrigerator maintains it's efficiency. http://www.searspartsdirect.com/frigidaire-refrigerator-parts/model-BFHS2611LM0/1428/0165000.html has another copy of the parts diagrams with the parts for sale.)
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
SOURCE: How do I tighten the refridgerator door handle on a Kenmore Side-by-Side Model: 106.57026600.
Service:
http://mrappliance2.reachlocal.net/land/
http://www.sears.com/sr/service_order/so_productinfo.jsp
DIY repear and diagnosic help:
http://www.acmehowto.com/howto/appliance/freezer/freezer.php
http://www.repairclinic.com/0047_3.asp
http://www.fridgedoctor.com/
SOURCE: Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
SOURCE: loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
