It sounds like either the battery needs replacing or you need a new power supply.
If it works while plugged into the power and only shuts off when unplugged then it's the battery otherwise it's the power supply.
Thread Equium P200D 139 battery seems to be dead
SOURCE: how to enable the microphone on Toshiba equium
Hi there!
Just follow the link (video) below for all information:
http://www.youtube.com/watch?v=sodMDs7rEEk
Please rate this solution if you found it helpful.Thanks!
SOURCE: how to change the cooling fan in a toshiba laptop model p200d-139
Instructions Shut down your Toshiba laptop, and then disconnect all cables. Close the
LCD lid, and then place the laptop face down on a flat surface. Position the
laptop with front edge facing you. Locate the battery pack near the top section of the laptop's bottom
casing. Press on the battery release button. Remove the battery from the
laptop. Locate the cooling fan compartment cover. Its location varies from
laptop to laptop, but it will be the only hardware cover with a vent in it.
Remove the Phillips-head screws securing the fan's cover in place. Remove the
cover from the laptop. Disconnect the fan's cable from its connector on the motherboard. Remove
the Phillips-head screws securing the fan in place. Lift the old fan out of the
fan compartment and set it aside. Removing the old fan will reveal the
processor chip. Apply a thin coat of thermal grease to the processor's surface
using a clean paper towel. This will prevent your new processor from frying
once you power on your laptop. Place the new cooling fan assembly inside the fan compartment. Align the
screw holes on the new fan with the screw holes inside the compartment. Replace
the four retaining Phillips-head screws, and then reconnect the fan's power
cable to the motherboard. Replace the fan compartment's plastic cover, and its
retaining Phillips-head screws. Replace the battery pack and reconnect all power cables and external
devices. Turn on your laptop to test the new cooling fan
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
