Why is my Philips brillance 220cw Monitor showing white screen?
Hi Fixya,
When I connect my monitor and then power to my pc, it only shows white screen. I tried all button on the right hand side, and all I can see is just a blank white screen. Does these mean my monitor is now history?
Regards
Alex
Try unplugging the monitor for several minutes and re-connect.
Also, you may want to re-seat your video card on PC.
If you have another monitor to check your video with, it would help.
Hope this helps.
Well, you need to find out first if it is the computer video card problem or not by trying another monitor with this PC, or try this monitor with another PC before goin any further.
Did it work before? Anyhing was doen to either the monitor or the PC?
Please post back what you find.
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen. Connect AC power. Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber. Reconnect VGA cable. Monitor should work. Close up the monitor in reverse order to opening it. If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Hi! If this is the case, the problem will surely be on the monitor cable going to the pc. If the cable is loose or faulty it will give you a no signal message. YOu will need to secure the cable of the monitor for it to work. Hope this helps and thank you for using FixYa!
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable. Which connections does your Philips monitor have?
