Every time I turn the key on to just let the windows up my engine fuse keeps blowing. I dine check under the dash and can't fine a bad ground no where and I have everywhere
If that is the only instance to blow the fuse; when the contact key is turned 'ON' the relay sets priority to 'start engine' mode, like directing the power to the starting accessories, now when instead you activate something else, the circuit is overloaded: Puff
SOURCE: 2004 1500 Dodge Ram Check engine light on
U0155 definition is lost communication with the ipc control mod , (instrument panel cluster) , reasons include faulty IPC , loose / bad connections at IPC , i read some forums and and some found connection issues at fuse box , when the problem exists you could try wiggling wires at behind fuse box or the back of the IPC try to locate source if indeed it is a connection issue .
good luck.
SOURCE: 1998 Dodge Ram 1500 4WD blowing fuse when turning left signal on
left side u got a short
u can wire up a buzzer or light to plug into where the fuse goes that blows when u turn on ur left blinker the buzzer will sound or the light will come on ,while the buzzer is on take apart left signals
and check wiring by moving harness around ,when u find the short the buzzer will quit
SOURCE: I have a 99 dodge ram 1500 4x4 with the drivers
Did you take a voltage reading at socket of dim one compared to bright one?
SOURCE: Power outlet in dash quit working
If you are referring to the cigarette lighter check the fuse in the fuse box. I sometimes over load mine with computer, chargers, GPS you get the idea and it pops.
SOURCE: 2002 Dodge Ram 1500 power door locks keep blowing fuse
by process of elimination!
one door at a time so disconnect 3 & keep changing the active one till you find which one isnt working
then test its circuits ok
Cheers rob.
