SOURCE: '94 kawasaki jet ski 750ss won't crank over.
if you subed it there is a good chance you may have sheered your timing key. its a preety easy fix. had it happen to me once
SOURCE: I have a 1989 kawasaki js 550 jet ski. The engine
Check the ignition coils to begin with and basically follow the wiring back to the stator making sure you have proper voltage at each component, also check to make sure everything is grounded properly, it is very common for the grounds to be corroded on marine equipment. I will have to check but I am sure I have a dealer service/ troubleshooting manual for kawasaki skis, so if you have any other questions about yours let me know.
SOURCE: I own a kawasaki 650 sx 1990 stand up jet ski. My
Starter bendix needs to be replaced.I get all of mine from E-Bay,get a flywheel tool and the job is done in about 1/2 hour.
SOURCE: how to replace seal on a jet ski
If the seal is in the jet pump, get an impellor tool and replace all the seals and bearings in the jet pump. You will have to pull the engine to replace the crankcase seals or the rear hull seal.
