Question about HP Compaq Presario CQ50-110US Laptop
Why won't my Compaq CQ58 laptop charge?
Compaq CQ58 works when plugged in but stays on 10% charge. Laptop won't charge at all: Appears to be charging when first switched on but this goes off after a couple of minutes with no extra charge on the laptop. Don't want to buy a new charger/battery if it's something more than this. Thanks:
Posted by Jasmine Wootton on
JWConrad
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
You most likely have a faulty battery or the charger is not proper to the device or the current getting to it isn't proper.
Posted on Jul 27, 2015
BHK6
    New Friend:
  • HP Expert
  • 27 Answers
Hi Jasmine,
I see that your battery isn't charging and there is a way to test to see if the battery has reached the end. I have included a couple of links below for you to test and calibrate the battery.
HP Notebook PCs Testing and Calibrating the Battery Windows 7
HP Notebook PCs Testing and Calibrating the Battery Windows 8
You can also try resetting the Microsoft ACPI-Compliant Control Method Battery which is basically the driver that communicates between the computer and the battery. There is a chance that it is corrupted.
Step 1. Go to Device Manager
Step 2. Select Batteries
Step 3. Right click the "Microsoft ACPI-Compliant Control Method Battery" that is listed there
Step 4. Click Uninstall
Step 5. At the prompt put a check in the box to remove the current driver
Step 6. Shutdown the computer
Step 7: Remove the battery for minute and then put it back in
When the computer comes back up it should automatically find the driver.
Step 8. Go to Device Manager
Step 9. Select Batteries
Step 10. Right click the "Microsoft ACPI-Compliant Control Method Battery" that is listed there
Step 11. Click "Search automatically for updated driver software"
Do the same thing with Microsoft ACPI-Compliant Embedded Controller if you see it listed.
Thank you,
BHK6
I work on behalf of HP
Posted on Jul 28, 2015
Doesnt swich on
this pc sold from 2012 to 2014 and is NOT NEW, at all.
sold with W7 and W8, only, new all have w10,
And HP does support still. (my guess till 2024)
no operating system stated by you btw.
ok,, I do the dead only.
wow a real service tag model stated. super good that.
can I assume the screen never ever show even 1 line of text?
ill assume that is true, and respond, i cant see your screens. so..
CQ58-A10NR
how to fix a LT , that is I presume DEAD .? black screen
simple steps on all DEAD LT
  1. take out the battery does it work now y/n???????
  2. does the ESC key BIOS key work? power on hammer ESC or F9 or F11, if those all work the BIOS IS GOOD and power is ok
  3. if BIOS is dead the power pack is bad. (or worse, worse in not limited at all with over 3billion transistors inside.
  4. see this?
http://pcdied.com/black-screen.html
The power pack is bad if the PC will not run with AC only. battery out.
the pack can be bad. AC line pack its like $15 , vastly less than the typ. $300 shop labor charge alone..
your support page is below!
https://support.hp.com/us-en/product/Compaq-Presario-CQ58-a00-Notebook-PC-series/5259206/model/5273664
Jul 24, 2017 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Scanner won't work with compaq cq58
You orobably do not have the required drivers for the scanner. I suggest you to browse the manufacturer's website and download and install the latest updates from there. Also if they recommend any utitlity along with driver intall it and then try to scan the document. This will hopefully resolve the issue.
Sep 19, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Can get the battery out of my compaq cq58-252sa laptop
On a jammed switch for the batt on the (old) compaq I would take in for repair so is not you the done that damages anything around the battery casing.
Mar 21, 2013 | HP Compaq Cq58-252Sa 15.6-Inch Laptop...
Why wont my Compaq cq58 laptop charge
hyjackers. from 2013
Gerrie Kotze wants answers to this question
buy a new battery first. ok?
then post your own new post with all symptoms,
99.90% bad batteries, some as old and 1 year old can fail.
if abused (means excessively deeply discharged over and over)
why wait, ever better why no own a spare good battery.
end the wondering...?
Jan 16, 2013 | HP Compaq Cq58-252Sa 15.6-Inch Laptop...
Compaq celeron B830 WINDOWS 8 BATTERY NOT CHARGING
It seems a few guys on here are missing the point, if you wish to check to see if you dc socket is faulty you need a good working charger and a multimeter set to DC volts.. Remove your battery and inside the battery compartment there are a series of brass looking contacts some are longer than others, the longer ones 90% of the time represent the Negative ( -V ) or Ground, Connect your black meter lead to one of the longer terminals and continue to probe your red lead on the other smaller terminals and see what reading you get.. if you see a small voltage thats dropping this normally means you are on the pins that connect to the output of the battery and as such capacitors on your main board are discharging (hence the voltage drop). if you see 3.3v on some pins this indicates the charging voltage and shows your dc socket is in fact working fine and that the problem is with your charging circuitry on the main board which is where i am at the moment, trying to find the relavant information to allow me to repair it, LOL hope this helps..
Jan 06, 2013 | HP Compaq Presario Cq58 250Sa 15.6-Inch...
Boot image did not authenticate
My laptop compaq CQ58 does not start up so it gives me this message selected boot image did not Authenticate. Press <Enter> to continue. If l press continue it switches off, Pliz help wat should l do
Dec 02, 2012 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
My laptop wont charge.when its running low at 10% i plug in my battery adapter it says its plugged in but not charging. I can only use it when my adapter is plugged in and i've left my computer sit shut...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 02, 2011 | Computers & Internet
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
HP Compaq Presario CQ50-110US Laptop Logo
204 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
