Top 565 Complaints and Reviews about Maytag Bravos
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.2 - 241 votes
This Maytag Bravos HE machine has the poorest design! ... So disappointed in Maytag - I have a 2013 Bravos washing machine that if I had it repaired again (less .... Called Maytag because my owner's manual stated I had a 10 yr warranty.
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
SOURCE: I have a brand new
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
SOURCE: MVWB850WQ1 Maytag Bravos MCT making loud
PART NUMBER: 22003593 ,door not want to activate switch lock and green wire I do not know where it goes.
