Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch
best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
SOURCE: We have 3 soft closing Toilet seats.Newly
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
SOURCE: toilet seat come loose and no obvious way to
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
SOURCE: loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
