Could this be a fuse problem?. A small button pops out next to the gear shift when the mixer stops. After 30 seconds or so I'm able to push it back in and resume mixing until it inevitably pops out again after another 20 seconds mixing.
SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
SOURCE: Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
SOURCE: hobart mixer 30 quart
this is an extremly difficult mixer to take apart if you are not tech minded do not attempt this
SOURCE: old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
SOURCE: How do I empty and
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
