Question about Xerox Office Equipment & Supplies
Xerox 5765 display does not work still on green color
Posted by usman on
Zahid khan
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
How to fix it I have the same problem.
and also the altboot method does not work for me as my copier would not boot from sub I have tried it .xerox 5765
Posted on May 24, 2016
  • 1 more comment
  • Bashir Ahmad
    Bashir Ahmad Jul 18, 2016
    Mamorey Ram problem replace the momery ram
  • Abrar Mughal
    Abrar Mughal Apr 22, 2018
    xerox 5775 reprint seriver is not avalibal
  • Zahid khan
    Zahid khan Nov 08, 2018
    i have fix the problem using altboot method.but for altboot method u hve to formt the flash drive in fat32 mode.this is the trick.
2 Related Answers
checkitright
CheckitRight
  • 1363 Answers
SOURCE: xerox majestik 5765 error codes
Sorry I am not familiar with this machine, usually if you press the start key for 3 sec it should show you the other codes? Good luck.
P.S.: If i run into anything I'll send it to you .
Posted on Jan 12, 2009
Anonymous
  • 62 Answers
SOURCE: xerox 5765 enter diagnostics
any 9 code is xerographic. This machine isn't worth fixing if you want me to be truthful. The parts alone will cost you more than enough. Look for DC12 on ebay or something to upgrade.
Sorry, but its the best solution
Posted on Jan 16, 2009
Xerox 3635 mfp. Stuck on software upgrade screen. How can I reset without operator panel?
You can try to download the firmware from Xerox and rewrite through Centerware. Open up internet explorer and type in the ip address of the unit. If that doesn't work you'll need to replace the User Interface Board, the software is corrupt. The part number is 140N63294. Can be purchased at:
http://www.iteminconline.com/140n63294_140n63294-xerox-3635mfp-pwb-user-interface.htm
Mar 03, 2016 | Xerox Office Equipment & Supplies
Model 5765. What does 09-362 fault indicate?
That error signifies that the toner concentration is high.
09-362 fault, enter dC131 location 09-276 TC lockout high. Check that it is set to '0'. If
set at '1' the toner dispense motor will not run
Jan 28, 2016 | Xerox Office Equipment & Supplies
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox workcentre 5775 doesn't send or receive faxes
Data Encryption / Data Description progress 1 hour xerox 5765
Mar 23, 2012 | Office Equipment & Supplies
Xerox majestik 5765 error codes
Jan 12, 2009 | Xerox DocuColor 12 Color Copier
I have problem with majestik 5765. fault code is 03-300. I don't have list of fault codes.
Hello sir; the status code means communication and memory failures, check the computor cable or connector.
Jan 10, 2009 | Xerox DocuColor 12 Color Copier
Xerox 5765 enter diagnostics
Jan 08, 2009 | Xerox Office Equipment & Supplies
Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Jun 19, 2008 | Xerox XL592DS (Silver) 19 in. Flat Panel...
2,650 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
