Question about Linksys WRT Computers & Internet
Want Boot-code Ver. v0.03 for linksys router?
Want Boot-code Ver. v0.03 for linksys router modelno wrt120n?
Posted by Shyam Suvin S on
    Top Expert:
  • Linksys Master
  • 76,708 Answers
0073 00207 00854620 00088776655
Posted on Jul 25, 2015
How do I find network key for wrt120n router
You will need to check the setting of your wireless router.
Do you have any computer connected to the network?
Using one computer connected to the network, you can open the router page and check the wireless router settings.
Check this link for Linksys WRT120N router setup and troubleshooting
2answers
2answers
What is the security code for the WRT120N router
IF you don't know the password to your router you will need to reset the router by sticking a pin or toothpick into the hole on the back label reset and re-configure your router.
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
2answers
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Where can i download a free installer for linksys wifi router with model # wrt120n
Are you trying to install WRT120N router?
You can do it manually without CD.
Connect the computer to the router. open the setup page and change the settings manually.
See how to setup Linksys WRT120N router
My wii will not connect to my linksys wireless router
Is it a new router? Your Linksys WRT120N needs resetting. Reset the Linksys router & reconfigure as per your requirement. I had two such routers giving trouble for the WiFi connectivity & which were new. You will be able to connect your router.
sonsunny
How do I reset my router password
Here is the step-by-step instruction to reset Linksys WRT120N Router
  • First af all you have to make sure the power is "On" . Power the router up while pressing the reset button located at the back of the router using pencil or paperclip
  • After around 30 seconds you will be prompted with the boot loader. Connect the boot loader using the standard IP address if you have not changed it (http://192.168.1.1)
  • Upgrade the firmware to the latest one from Cisco site
  • Power cycle the router and allow it to come up.
  • When it is fully up, press and hold the reset button for 5 secondsThe LED light will blink indicating that you're done holding the reset bottom. If the Power LED won't blink try to press and hold the Reset Button for I minute and then power cycle the router for another 1 minute.
  • Power cycle the device and now you have reset your linksys WRT120N router See the following link if you forgot to setup linksys router
(http://infoteknotainment.com/reset-linksys-wrt120n-router)
Open Questions:
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
