Question about Home Fencing
I have mighty Mule 350. today it shut and then was beeping constantly,I turned it off and tried to turn it back on it does nothing. it does not beep when its turned back on it. It does nothin at all
Posted by Chris on
  • Chris Jul 25, 2015
    Yes it does have power
Claude Kayser
    Top Expert:
  • 9,098 Answers
Do you have power?
Posted on Jul 25, 2015
Testimonial: "yes, to took cover off and power light is on"
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Computer turns on and beeps.
I suggest you check you memory sticks, and make sure they are seated properly. The long beep usually signifies a memory problem. If you have 2 memory sticks, I suggest removing 1 of them, then tuen on the PC, if it still beeps, powerdown by holding the power button in until it shuts down, then replace the removed one, and remove the other, if it boots, fine, then you will need to replace the memory that you have removed, but,,,,,if you only have 1 memory stick, I suggest you replace it, if the pc still beeps a long beep, then 1 of the memory sockets is bad, and a motherboard replacement is needed, either case, that long beep is a memory problem.
Posted on Jun 17, 2007
Anonymous
  • 118 Answers
SOURCE: HP Compaq dc5000
Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Posted on Feb 06, 2008
myob247
Georgia B
  • 1342 Answers
SOURCE: 6 beeps at start up
Sounds like a processor or cpu failure.
Beep Codes
Please vote if you found this information useful.
Thank You
Posted on Apr 18, 2008
byteguy
Art Ellison
  • 2229 Answers
SOURCE: Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Posted on Feb 01, 2009
Anonymous
  • 404 Answers
SOURCE: Computer Beeping, something loose?
looks like u've done most of the steps.
put everything how it was, change the ram to the next availble slot. remove power, remove bios battery "like a watch battery" wait 10min and put back on and power on see what happens
Posted on Mar 11, 2009
Gate beeps when turned on and opens on its own mighty mule dual gate
There are limit switches that set the open and closed position and also a sensor for obstructions. Check those items for shorts and proper connection
Feb 10, 2017 | Cars & Trucks
Is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Its kinda hard but if you follow the info in the owners manual for your truck it works. It is not rolling code like a gargae door this is a dip switch on or off .
Jun 07, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
The unit beeps
I am getting these directly from the user manual (available here: http://www.apcmedia.com/salestools/ASTE-6Z7VAQ_R3_EN.pdf)
Issue: On Battery - UPS is supplying battery power to the load connected to the Battery outlets.
Visual Indication: Power On LED - ON (off during beep)
Audible Indication: Beeping 4 times every 30 seconds
Stops When: UPS transfers back to Power On operation, or when UPS is turned off.
- OR -
Issue: Sleep Mode - During On Battery operation the battery power has been completely exhausted and the UPS is waiting for utility
power to return to normal.
Visual Indication: None
Audible Indication: Beeping once every 4 seconds
Stops When: Utility power is restored, or if utility power is not
restored within 32 seconds, or the UPS is turned off.
All other issues are CONSTANT tones, which you did not specify, or there are no audible tones associated with it.
Apr 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Gate open and beeping,it will not close
Well if your board is getting power and the power supply is ok, but when you try to activate the opener, and do not get a response, than you have a faulty board, im Guessing you have a GTO 1000, Mighty Mule 700, or Mighty Mule FM500 series
Mar 13, 2009 | GTO Inc. / Mighty Mule Gate Opener Battery...
Constant beeping and will not re-boot
Question- the beeping, is it short (1 second beeps) or long (2 or more seconds) and how many before it stops? or doesn't it? does it have any rhythm? The beeps correlate to some hardware problem, if you want to check the beeps yourself, just google "Bios beeps" and it will bring up a table of what the beeps mean.
J
Jan 07, 2008 | Computers & Internet
Home Fencing Logo
1,945 people viewed this question
Top Home Fencing Experts
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
