Question about MTX Car Audio & Video
I have an mtx thunder tc4004 amp and when ever i turn it on the speaker moves when nothing is playing and only the bottom outputs are working
Posted by Cody Fuller on
Kelvin
    New Friend:
    Problem Solver:
  • 6 Answers
Make sure that your rca cables are still plugged in to the receiver.
Posted on Nov 14, 2015
5 Related Answers
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: confused
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
 Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Posted on Oct 19, 2007
Anonymous
SOURCE: 4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Posted on Mar 09, 2008
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: wiring details
Hello bpuentes,
Here's a link to the wiring diagram PDF.
http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/TA81001InstallWiring.pdf
Hope this helps.
Posted on Mar 31, 2009
Anonymous
  • 84 Answers
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Posted on Jun 14, 2009
Anonymous
  • 68 Answers
SOURCE: mtx thunder 1500 watt amp no sound
Even if there is no visible damage, it could be that one of the transistors is blown, Use a multimeter to check the resistance of the transistors.
Posted on Aug 05, 2009
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
I have a kenwood 350watt amp on 2 mtx thunder 12's
Hello
Check the impedence of the connected speakers. if any impedence mismatch is there, the amp will sense it and will cuto the output OFF. Use only specified speakers only. The impedence of speakres are expressed in "Ohms". Select all speakers of same impedence. If 6 Ohms is the output impedence of the amp, use only that Ohms speaker. Never use a speaker less that this Ohms. You can use a higher impedence speaker, say 8 Ohs or 16Ohms. But never use lower impedence speakers, of connect two speakers in parellel connection, which will relult in overloading. I think that I've made a satisfactory solution to you. Please don't hesitate to rate this solution. Good luck
Wish you a Merry X'mas and Happy 2012.
Gopakumarg43
Dec 21, 2011 | Kenwood Car Audio & Video
My mtx thunder 6500d amp hums when connected light turns on but no output
Make sure you have a proper ground wire connection. The ground wire should be connected solidly to the vehicle chassis in a paint-free location. If it is loose or there is paint t the connection site, you will have problems with the amp output. Also check the speaker wires to see if they are touching the vehicle chassis. This will cause a short circuit and you will not have output from the amp. Finally, check the leads from the head unit. They should be RCA cables, and should have a good connection to the amp.
Feb 22, 2011 | MTX Thunder 6500D Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Can you run two mtx 6500d amps in parallel for more power?
Not suggested to parallel the output of two amps. Instead take each amp, find out what the amps lowest impedance it can drive is and select your speakers based on that. According to MTX these are stable down to 2 ohms without a rated output power of 500Watts X 1. If you get two dual voice coil subwoofers with each coils characteristic impedance of 4 ohms, when you parallel the two coils you will get a 2 ohm load. Just maek sure the speaker can handle the 500 watts.
Jan 27, 2010 | MTX Thunder 6500D Car Audio Amplifier
My (TC4004) mtx amp wont turn on. My fuses isnt blown.I think my amp is fried. Any suggestions?. I was told by a friend that i may have to relace the the two yellow connectors that are on my amp..is this...
If your talking about the speaker connections on the amp than no,make sure the amp is grounded to the vehicle,and make sure your power and rca are connected,if so check all fuses again,your amp may have a fuse,if its not blown your amp is probably fried.
Oct 12, 2009 | MTX (TC4004) Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
280 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
