it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
You description of "...no video but with audio..." could indicate a number of possibilities:
power supply section;
tuner
video amplifier/selector;
vertical section;
horizontal section .
Other ideas are:
Since it has still sound, then the power supply is a least likely possibility;
Since it has still sound, then the tuner is a secondary suspect;
Since the menu shows, then the vertical and horizontal would be highly unlikely.
which eaves us the video amplifier or electronic/soft selector as the most likely culprit.
Further diagnosis would of course would require a fair
familiarity of electronic components/circuitry and safety procedures,
use of a DVM and a soldering iron. It would be to your added advantage
access to a service manual or at the very least a schematic diagram
with voltage readings. Should you be uncomfortable performing a DIY
(do-it-yourself), perhaps your best bet would then be to seek the
services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
