Durabrand 5.1 Surround Sound Computer Speakers Logo
Question about Durabrand 5.1 Surround Sound Computer Speakers
My Polka surround 3000 randomly stops working. By turning it off then back on it starts working again
Kia sedona 2009 diesel randomly stops.all lights on dash come on. the car stops .i turn off ignition.turn back on.only check light is on but car starts again and we drive on until this happens randomly...
Can you check what does the Check engine is on you can buy a cheap scan tool scan the system at least you know why it is on
that way we can help you
1helpful
My Polka surround 3000 randomly stops working as if muted. By turning it off and then back on it works fine until it happens again. ....
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Brush Bar Randomly Stops Turning
There are numerous things that could cause this. It would be best to find a qualified Dyson repair person to determine the cause of your DC28.
Screen only turns on randomly during start up, led lights are lit, laptop sounds like it wants to turn on and stops, then tries again, then stops. Problem happens about 9 out of 10 start ups, and when it...
remove battery, press and hold power button for 5 seconds, then wait 5 minutes, put battery back in securely and try again. If it powers on, try and look at the power meter to see if it is registering the power supply. You could have faulty memory chip or faulty power supply
Display on my JVC HT-L1 randomly stopped working
1helpful
Speakers stopped working
I get such a thing from time to time on different systems. What I do:
1. Open the Sound Control Panel (the one on this present PC is named: "SoundMax Control Panel").
2. Enable or Disable a certain feature (something like "Virtual Theater Surround" or "Virtual Ear" or "Acoustic Environments" or so on).
3. Click Apply and the sound is back in your speakers.
4. If you want, you can undo the enable / disable and the sound still works.
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Memory?
Bad RAM.Buy new ram and everything will work OK?
Check also HDD if it works fine!!!
Top Durabrand Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
