Here's a link on bleeding your system. 580 Case 580D Backhoe repair summary for hydraulic and brake systems...
SOURCE: bleeding passat brakes
it will need to get a scan tool on it to remove the light as the abs unit would have logged a fault.
SOURCE: abs brakes
there are so many small orifices in the abs controller that if you are trying to bleed manually you cant do it I have found that vacuum bleeding aor pressure bleeding are the only ways and then sometimes they dont work it has to go to the dealer sorry some things only the dealer has the secrets and noone can get them away from them sorry ran into this one myself
SOURCE: brake bleeding procedure on 2000 vw golf
get a one man bleeder kit from halfords (about £7) and then you can go around the car and bleed the brakes without a assistant, you just attach the tool to the nipple on the caliper, loosen the nut, press the brake pedel a few times till there is no more bubbles in the hose and then move on to the next corner, there is a specific way to go around the car but if you start at the back and finish at the front it should be ok
SOURCE: Spongy brakes after bleeding them 2 times. Should I try to bleed the master cylinder or replace it?
Honestly your guess is as good as mine. But I don't think the master cylinder is NOT bad you still have air in the system. Get a big bottle of brake fluid bleed all four sides until you run out of fluid or your brakes work properly. You should divide the bottle's content in four, then use each quantity in each side. You'll be removing air and contaminated fluid from the system. Get a small hose that fits on the bleeders and an appropriate container. I have a good feeling if you do this your brakes will work just fine. I don't know how you are bleeding the brakes. I'll let you know the proper way just in case. This is a two man job, with the wheel off, have someone start the car. Have them pump the brakes a few times to get pressure. 1With the brake pedal UP open the bleeder, 2then have your assistant press the brake pedal all the way down and leave it completely pressed down. 3Close the bleeder valve, once close and only with the valve closed have'm release the brake. Repeat as necessary, bake depressed, open valve first then press brake. DO NOT depress until valve completly closed. Close valve THEN depress. Good Luck!
SOURCE: BLEEDING REAR BRAKES CAN BLEED ONCE THEN SECOND
Sounds like a problem with the proportioning valve. Try not to push the pedal down to far when bleeding. The valve sounds like it is getting stuck closed, and takes a little bit to release and allow fluid to pass again.
Fig. 1: Loosen the front brake line in order to bleed the master cylinder
Fig. 2: Connect a bleed hose from the bleed valve on the front caliper to a jar of brake fluid
Fig. 3: Always follow the lettered sequence when bleeding the hydraulic brake system
Hope this helps to solve it; remember to rate this answer.
