Question about Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator
Amana French door refrigerator Freezer drawer on bottom hard to pull out to open freezer How can this be fixed?
Posted by M Reilly on
Claude Kayser
    Top Expert:
  • Amana Master
  • 9,098 Answers
By thawing.
Posted on Jul 24, 2015
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
My bottom mount french door refrigerator, the upper part does not cold, it's warm
Sorry your having trouble so soon!
First thing you need to check is inside the freezer section.
The freezer fan, the fan is W10128551 and should be running
along with the main compressor. Since the freezer is working,
I would check the food on the top drawer or on the freezer door shelf.
They too might be soft..without the fan.
I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
John Wright
Jul 27, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
How to take the front grill off?
the grill should just snap off with a pull, evenly from both sides. If coils can be accessed from the front, there are no more coils in the back. The screwed on cardboard in the back is covering a fan so it can pull air directly over the compressor and evaporate the water in the drain pan. You should periodically check to see if water is draining into the pan, if not, the evaporator may be getting heavy ice build up, therefor not cooling 100%
Jul 15, 2010 | Amana 25" Cu Ft French Doors Bottom...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
148 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
