The CS6229-3 base shorted out, bought a CS6229-2 base so I can use the hand sets from the -3 model. Connect new base to power and plugged battery's into hand set and screen says connecting. Tried to do a reset and nothing is working.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
SOURCE: wired base unit
Try a simple thing, replace the phone cord that goes from the wall to the phone with a new one. That'll make sure you still have a good phone connection. Cords cheap.
You have a power transformer that plugs into the wall. See if you can find a replacement at a surplus store or Radio Shack (a different store) Take the old one with you so you can match the voltage/ampere and connector. If its new it will work fine. If its surplus, it's hit or miss.
If that does not work or you don't want to bother buy as new phone. With the constant upgrades you might find one with better features you'll like more. Who knows.
Good luck
SOURCE: Philips Zenia 200 phone not working
Hi Becky;
Actually I don't have any answer to your problem, butme I am looking for the owner's manual of the Philips Zenia 200.......please, can you provide me with a copy ?
Thank you.
My e-mail is [email protected]
SOURCE: i had a uniden 5.8 cordless phone with 2extra hand
problem solved threw uniden in trash and bought another brand
SOURCE: Battery not Charging
hi :) about battery mayb just a little pro only. u can try to check yr battery charging detect point.i mean the gold colour :) or the charger oso have the gold colour detect point.(it same position detect with yr battery point oso) well,check the both item Point wt i write as above.if it look some dirty ?? juz take some tissue paper clean it up :) Ps: after clean still not work,pls check the charger wyre. good luck :)
