I took the back off to clean my filter, now it wont power on
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
Nicely done Kristen McMillian...
That's exactly how I got started...
I had a trouble & ended up fixing it myself.
Then after a while I noticed how I got better at puzzling out what information could be divined from very little... Still working on my smooth finish: what comes to you naturally.
Good job!
Thanks, it worked right away my 96-year-old dad was trying to help out and had cleaned the filter while i was at work and reassembled it wrong. i came home and found it not working.
SOURCE: how remove and clean filters from Brookstone pure ...
how to remove and clean filters for the Pureion UV air purifier?
SOURCE: Pure Ion will not turn
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
