Question about Konica Minolta Bizhub Press C6000 Copier
Replace toner filter on Konica Minolta C6500
How to Fix Toner Full Cod
Posted by Pitney Bowes on
  • Norman  J Weimar Jr
    Norman J Weimar Jr Nov 22, 2015
    Hi Pitney Bowes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? is there a code or filter to be replace procedure
5 Related Answers
Anonymous
  • 115 Answers
SOURCE: Konica c6500 error code c-2451
What error code.
Toner sensor's are usually at the far end of the Toner Cartridge. It will have what looks like a connection, silver or bronze wire, or a chip look thing, if it is dirty it can cause error codes as it is not making contact with in the machine.
Posted on Oct 25, 2008
Noyb merlin
  • 38 Answers
SOURCE: how do i replace the
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
Anonymous
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
Anonymous
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
Anonymous
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Posted on Apr 07, 2010
Konica Minolta 1580-MFP how to reset replace low toner message printer ?
  • Purchase OEM toner, toner has chip on it chips say toner case is empty it is empty you replacing the toner will not fix that
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 04, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Toner recovery box
my mechine is asking me to set my toner recovery box. how do i do that?
Mar 03, 2014 | Konica Minolta C6500 C5500 C6501 C6000...
I have c6500 konica minolta bizhub and i am getting c2452 code what i shouls do?
check the magenta developer unit, might need to replace the developer, also might have to replace the Toner sensor located under on the unit
Dec 28, 2013 | Konica Minolta bizhub C250 All-In-One...
Add toner k message
add black toner than
Nov 22, 2013 | Konica Minolta C6500 C5500 C6501 C6000...
WHERE IS THE WASTE BUCKET ON PRINTER KONICA 4690MF
Found this on the support site
When the waste toner bottle becomes full, the message "WASTE TONER
FULL/REPLACE BOTTLE"
Konica/Minolta Support
Go to "Ch. 7 replacing consumables" > "Replacing Consumables" > "Replacing the Waste Toner Bottle" this is found on page 165 of the user guide. This walks you through replacing the waste toner bottle.
Hope this helps. GOOD LUCK!
Oct 16, 2009 | Konica Minolta Magicolor 4690MF...
What does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
What error code.
Oct 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub Press C6000 Copier Logo
910 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
