Question about Samsung HG32NA470PF 32 LED-LCD TV - HDTV HG32NA470PFXZA -
Double image, how to solve this ?
Double image, im searched various videos,tutorials and its a problem in T-CON but my tv dont have a tcon board with 2 flat cables
Posted by arthur on
    Top Expert:
  • Samsung Master
  • 76,466 Answers
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Posted on Jul 22, 2015
  • Sp Gupta Jul 24, 2015
    Is your problem solved or still want solution?
My TV is Toshiba 32c120u. It started to show double image a few days ago. Is this a problem with a T-con? If you need further information, I can send you a video to show you how the screen looks like.
The TCON board or the LCD panel is faulty. Can Confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 06, 2017 | Toshiba 32C120U
HOW TO SOLVED DOUBLE IMAGE
The problem with your TFT panel, please consider the replacement of your panel module.
or you can solve this problem buy disconnecting some strip connections from T-CON board to the panel, BUT THIS IS NOT A COMPLETE SOLUTION FOR THE PROBLEM, this may be a temporary solution, you can find this type of solutions with video tutorial on www.youtube.com
Apr 25, 2016 | Sony KLV-32EX330 Series BRAVIA Direct...
Model UN55B7100WFXZA. Why Double image & horizontal lines on top part only?
T con board faulty or the LCD panel is faulty . Can confirm by replacing the Tcon board .
If you wish to get some details about tcon board problems ; check the site linked here. Pull up older posts.
Apr 17, 2016 | Samsung Televison & Video
I have a Samsung model LN40D630 with double picture ,I changed the t - CON BOARD AND ribbon still have a double picture what next?
Always the double image will not by the faulty T con board. There can be problem with the buffer ics which are located in between the tcon and the lcd panel . The buffer ics are not replaceable one because it integrated to the ribbon which is moulded to the panel. Either you have to go for a new panel or a new tv.
Jan 07, 2016 | Samsung Televison & Video
My LCD TV bravia model kdl-37v4000 is shown picture nagatively, which part of componend to be changed. If can be to fixed without service man. Where I can buy and how much the cost will come.
You have to change the t con board of the tv. Even after replacing the t con (added image of the t con )board the problem exist the you have to change the lcd panel. What ever it is you have to change the t con board to confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Tcon
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 19, 2015 | Televison & Video
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
Nov 03, 2015 | Samsung Televison & Video
Need to know if T-Con board needs replacement for my Samsung LCD TV?
Hi Michael,
Before replacing it, please check and thoroughly clean the flat ribbon cables to and from Tcon board. It may help. It is a delicate job and requires all the care. You may watch some Youtube videos about how to do it.
Aug 13, 2015 | Samsung Televison & Video
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
Samsung HG32NA470PF 32 LED-LCD TV - HDTV HG32NA470PFXZA - Logo
166 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
