Cars & Trucks Logo
Tamara Jordanov Posted on Jul 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My outside air temp is reading at -40 on my 2008 Pontiac Torrent. What is the right sensor and where is it located?
Jeff Armer
Level 3:
  • Pontiac Master 15,575 Answers
  • Posted on Aug 07, 2015
Jeff Armer
Pontiac Master
Level 3:
Answers
15575
Questions
Helped
7111741
Points
73899
Ambient Air Temperature Sensor (UH9)
At the front of the vehicle, at the lower left side of the front bumper bar
Pin
Wire
Circuit
Function
A
0.35 L-GN/BK
735
Ambient Air Temperature Sensor Signal
B
0.35 YE
61
Low Reference
2007 Torrent temperature gauge not working correctly. The car is not overheating. All other gauges working fine. i have changed the temp control sensor. Looking for insight. Thanks
You might have an air pocket trapped in upper radiator hose. If the coolant was low, refill and open bleeder screw to let air out.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Where is the IAT sensor
Although I am not familiar with your specific engine, the intake air temp sensor must be located in the air intake box or somewhere in the air stream between there and the throttle body. Usually located just after the air filter to give good reading of outside air temp.
The outside temperature gauge on a 2009 g5 Pontiac is not reading right how do you fix it
There is a outside temp sensor mounted on the radiator support in the front of the car,sensors get dirty or just fail
3helpful
A/C blows but not cold air....the temperature reading is off...but then sometimes the temperature reading is fine and the air works
The outside air temperature is reading sometimes off then the ac does not work? The ambient air temperature sensor located right by the front grill is probably malfunctioning.If it reads below a certain temp it sees no reason to turn the air on so it doesn't let you.
6helpful
2002 Bravada outside temp reading too low and prevents air conditioner from turning on
replace outside temp, sensor and check your refrigerant for recommended pressure, your outside air temperature sensor is located infront of your car, upper/ insidegrille
I have a 1997 Pontiac Grand Prix air temp sensor may be bad
the air sensor yur thinking of is usually found out front of the car on the post that supports the hood latch betwween the radiator assemblies and the oute decorative grill. go to your auto parts store like autozone and ask for the ambient air temp sensor. then if they can, ask for a diagram of its location. Its real easy to replace usually one bolt and one wire clip. Autozone has /offers these do it yourself repar guides that can help you .
1helpful
1999 pontiac grand prix gt dual climate control not working prope
The sensor is located near the hood latch area in front of the radiator. If the temp is reading incorrectly, chances are it is defective. You can purchase a new one, they relativly inexpensive.
Disconnect the electrical connector then remove the sensor.
Good luck, let me know.
Regards,
5helpful
2answers
Misreading outside temperature sensor on 2001 Audi A4
There are four sensors for ambient tempurature and they work in unison to provide information to the temp reading on the dash, the heater control head ( where to direct air, blending of warm/cold/outside/inside air flapper controls) depending on the ambient temp and the inside air temp sensor located just above the radio as well as the sun sensor on the top of the dash as well as the a/c compressor head.
When you start your car, the body control module takes the readings from all sensors, outside air temp located in front of the radiator, air temp sensor located in the airbox ( senses temp of air being drawn in from the outside into the air box), coolant temp, inside air temp sensor and the sun sensor on top of the dash (this is why it takes a few seconds for the climate control system to begine when you start the car). The intake air sensor is 1st priority, inside air second, coolant third, ambient 4th and sun 5th. For instance, if the sun sensor reads the sun is hot but the interior sensor reads cold, the inside akes priority. The goal is for the system to achieve a tempurature inside the car that matches the selected temp. It uses all of the sensors to set the system up to achieve that goal as quickly as possible.
Example; Its mid afternoon, sunny and 40 degrees outside adn your in stop and go traffic. The intake sensor reads 40 degrees, the outside sensor reads 60 degrees (heat from radiator...engine heat protrudes into cabin) and the sun sensor reads high (sun is strong). The system is set for 72. priority one sensor reads 40, inside sensor reads 65, ambient reads 60= system will blow hot air to the floor out put, dash outlets will lightly flow 65 degree air so the sun doesnt roast you yet your feet are cold(if it blew hot air from all outlets, your upper body would be hot but your legs/feet would be cold). as the interior sensor reaches desired temp, air will be distrubuted through thee dash, defrost and floor with the warmest air coming out the floor and defrost, coolest air out the dash vents. Its a complex system!
The two sensors that will screw the system up the most are the intake and interior sensors. the system will function reasonably well with just those two sensors though it wont blend air temps between outlets if the sun sensor isnt working. If the outside sensor fails, it simply uses the intake sensor, if the intake sensor fails it will rely on the front sensor. However, since the intake takes priority over the outside sensor, if the intake sensor sends incorrect resistance info rather than failing, it will take priority and cause the unit to malfunction such as in your case.
The intake air sensor can be changed from the outside with patience. If it where me, I would pay the two hrs labor and let the dealer do it right.
Kevin,
Kevins Small Engine service,
South Berwick ME. 03908
Outside temp reading on climate control wrong
it may afect the climate control to operate right,
try to locate the temperature sensor than most times is in the lower side of the wilshiel and on top of dash board and see what happend
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
