Question about LG Over-the-Range Microwave
Power 100 on display - LG Over-the-Range Microwave
Posted by Sue clark on
  • Ken Wieczorek
    Ken Wieczorek Aug 02, 2015
    Hi Sue clark, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Model # all
    anything it dose We can help you with repair
Power it stays at 100% want 50%
Place the items inside the unit and close the door. Set the cook time, then press the "Power Level" button. When the display asks for input, press "5" for 50% power. Then press START.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
How do I set the power level
Enter the cooking time. Press the Power Level button until the desired level is displayed - Level 1 = 100%, Level 2 = 90%, ... Level 10 = 10%.). Press Start button.
Dec 10, 2015 | Sharp Carousel R530EST Microwave Oven
Can't determine high or low on power control
put a cup of water in the cavity and set for 1 minute, after which time you can feel the temperature. Switch to the other power setting and repeat with a fresh cup of water. This will either be hotter than the first or much cooler. Most microwaves use 100% power for full and 30% power for defrost, with 50% usually being lower or medium power. Straight-forward physics. The more power the hotter the water becomes. Hope that helps.
Dec 19, 2013 | Sharp R-303CW Convection / Microwave Oven
Not heating digital display says
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 11, 2010 | Maytag MMV1153A Microwave Oven
Whirlpool microwave MT8066SE does not heat but the display works, and the turmtable goes around. Power is set to 100%.
heatman101
ruiury
Oct 08, 2009 | Whirlpool MT8066SE Microwave Oven
Dacor Microwave Touch Screen lite but blank
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here and replace it yourself for just over a hundred.
Sep 29, 2009 | Dacor DMT2420SS Microwave Oven
Call engineer and E-10 on display on amana commercial URFS518S Micro wave oven could you please tell what the fault is and how i can cure it. Regards.
E10:
An attempt has been made to program the oven for more time than allowed.
1. Press STOP/RESET pad.
NOTE: Maximum cooking time is 60 minutes except when cooking with full
power (100%). In case of full power (100%), maximum cooking time is 20
minutes.
If that doesn't work, leave it unplugged for maybe an hour then try again.
An owner's manual that may work for you is here.
Oct 21, 2008 | Amana Microwave Ovens
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
LG Over-the-Range Microwave Logo
630 people viewed this question
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
