Question about Remington MicroScreen DA-307 Electric Shaver
How do I disassemble it to replace the battery?
  • Anonymous Oct 05, 2016
    Same problem. No help here yet. I'll post if I figure it out.
Mister Danger
  • 5,631 Answers
Found this solution provided by eversolejay
The plastic cover faceplate on the front where the on/off switch and LED indicator lights "pops" off. (you will need a sharp pen knife blade to get into the seam and start this process.) Once the faceplate is removed you will see 4 phillips-head screws that hold the two halves of the body together. Taking the body apart will reveal the two rechargeable batteries, but the bad news is that these were not designed to be replaced and are actually bonded (glued) to the control circuit board.
Posted on Oct 07, 2016
Barrissimo
  • 30 Answers
How to open it was described at a site I found:
To open the case on a Remington DA-307, remove the foil and blades. There are 2 small screws on the side of the cutters. Remove these and pry the top apart. I had to wedge a small screwdriver between the halves to get started. Pinch in the sides of the shaver about midway while continuing to pry and the two mid tabs will release. With the switch side facing up, carefully and forcefully pry it open while twisting the top and bottom in opposite directions. Slip a small screwdriver into the groove that starts just below the side grips and slip it down about 1/2 " and twist. This should release the bottom tabs.* * * * *
I was able to pry it apart this way, and hope to succeed in replacing the 2 batteries, which are AA size 600mAh capacity with solder tabs. They are glued in but can be pried off the circuit board. A small spring fell out of somewhere, I think from under one of the buttons that release the screen head. Will post again if I succeed in replacing batteries and re-assembling.
Posted on Oct 05, 2016
  • Barrissimo Dec 02, 2016
    Was able to replace batteries and re-assemble... Shaver works, BUT the beard trimmer doesn't. There's a small plastic piece linking the vibration source to the trimmer blade assembly that can fall out of place during disassembly. Getting it back exactly right so far has escaped me. It LOOKS like I have it right, but the trimmer doesn't cut hardly at all, so there's some kind of alignment issue. Considering the time and money spent, I might have done better buying a refurbed model, and I say that as a habitual fixer.
robert
  • 2,536 Answers
Usually starts with screws on bottom of shaver where power cord is plugged in. most shavers have soldered in batteries, not an easy replacement.
Posted on Jul 20, 2015
    Obviously, you don't have this shaver. There are no screws at the bottom as described. There ARE 2 screws to be seen if you lift off the shaver screen, but they seem to be insufficent. There are others... somewhere. DON'T POST GARBAGE ANSWERS.
Rplacment Battery cover for. Bc92xlt
When you replace the battery, you might need some phone opening tools, disassembly tools, replace tools, you can choose Vip Fix Shop Team. http://www.vipfixphone.com/phone-disassembly-tool-repair-87_135/vipfix-13-in-1-iphone-repair-opening-tool-kit-pry-tool-for-cell-phone-fixphone-3741.htm
Dec 15, 2017 | Cell Phones
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Need to replace battery door.
    i have not replaced the battery door but have disassembled an S5000 following the service manual
    it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
    Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
    How do you replace a battery on a Braun 7680 Shaver?
    I replace my Bruan 7680 battery. I place the order for battery from Amazon, cutter& foil from goodmans.net. The following is my procedure 1.Using a small flat screw driver to plier the plastic socket lock (Where the charging located ) 2.Disassemble left and right plastic holder 3.Disassemble plastic cover top and bottom 4.Take out the circuit board where the battery mounted on. Please be careful at this process you could ruin the circuit board while taking the old battery out(I used a soldering and a small wood stick just to take the extra flux away from contact to other on the circuit board).It is not as difficult as I thought. 5.During your install a new battery please make sure that the batter pole does not go the same way(Check direction of a battery before taking it out so you do not put in the wrong direction) 6.Putting them back together. Note #special tool required to take out the circuit board from a mounting?My the battery replacement came with the tool)
    Apr 19, 2011 | Braun Activator 8595 Electric Shaver
    I need instructions on replacing cmos battery? Where is it located on the hp compaq nc 6220 laptop
    Please click here to open the service manual
    1.Prepare the computer for disassembly (refer to Section 6.3, “Preparing the Computer for Disassembly,” for more information).
    2.Remove the cmos battery (refer to
    Section 6.24, “System Board,” for more information on removing and replacing the RTC battery).
    CompQ
    May 12, 2010 | HP Compaq nc6220 Notebook
    How do i replace the battery on gateway cx200x
    remove main battery by sliding battery lock to unlocked position, then slide battery release latch and slide battery out. If you are looking for how to disassemble the notebook to change the bios/cmos battery, you can get the service manual at mpcdriver.com with complete disassembly, reassembly instructions and pictures
    Nov 09, 2009 | Gateway CX200X Tablet PC
    Need to replace the CMOS/BIOS battery on a Dell Latitude C610 lap
    Hi there
    You will probably need to disassemble the laptop to get to the CMOS battery as it will be attached to the motherboard, the battery looks like this >>>>>
    For instuction on how to disassemble the laptop go here >>>>>>
    http://support.dell.com/support/edocs/systems/latc610/sm_en/index.htm
    Good luck and thanks for choosing FixYa!!
    Jun 04, 2009 | Toshiba Satellite M60 Notebook
    Remington MicroScreen DA-307 Electric Shaver Logo
    1,530 people viewed this question
    Top Remington Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Robert McClure
    Tony Paewai
    Level 1 Expert
    Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
