Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Shark model by clicking the link below.
Euro Pro Shark EP600 Owner Manual
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: This is a EURO-PRO X
There is usually a heat sensitive fuse link installed in the handle and is incorporated in the cord connection. If the machine gets too hot or is run while dry, the fuse can blow. You would have to replace the fuse, as they are not resetable.
SOURCE: The belt broke on my my SHARK Model V15Z and Euro
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
SOURCE: i need a user manual for the shark euro pro s3101
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;j
SOURCE: i cannot find manual for
go to.... http://dl.owneriq.net/6/6639ab83-34ea-0a44-d571-45fe5b5a50d3.pdf it is the instruction manual
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
