Ovens Logo
Jorge Berea Posted on Jul 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't close the oven door - Ovens
  • Daniel Youngman
    Daniel Youngman Jul 20, 2015
    Hi Jorge Berea, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Steve Butterworth
Level 3:
  • Master 938 Answers
  • Posted on Jul 20, 2015
Steve Butterworth
Master
Level 3:
Answers
938
Questions
Helped
240949
Points
3298
Hi Jorgey,
Either there's something inside that's stopping it closing properly or the hinges have been deformed and are not working correctly. So clear out the oven and try door. Otherwise inspect hinges carefully for deformation. If necessary remove door and hinges. Carefully try to reshape the hinges. If this fails you need new hinges
The oven door doesn't close tight
Hello, Anna -
The problem of your oven door not closing tightly could be caused by one of several problems:
* A problem with the door hinges
* Broken oven door springs
* A problem with the gasket inside the edge of the oven door
This article from the San Francisco Examiner newspaper describes the problems and how to fix them:
http://homeguides.sfgate.com/fix-oven-door-not-close-properly-28760.html
Best wishes.
Feb 07, 2018 • Ovens
1helpful
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 • Ovens
Oven door doesnt close well
I'm not familiar with your oven but most oven doors are very similar in operation. When the door doesn't close well it's generally because the hinges have been stretched/bent when the oven door has been open. To see if this is the case, open the door fully. If it's stretched the door will open past 90 degrees (slope down instead of being horizontal). The easiest way to fix this is to bend it back. Place something as a spacer between the door and the oven on both sides (like a spanner handle or anything strong and about 8mm thick) as close to the hinge as possible. Close the door against it carefully and push the door closed. Do it a little at a time and remove the spacers and try the door each time until you are happy that it closes nicely again. It should be spring loaded closed slightly.
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
OVEN DOOR IS NOT CLOSE PROPERLY.
which subway are you , if the door doesnt close properly you may need new hinges
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Oven door does not fully close
The usual reason for oven doors not closing properly, is weak door hinges,if it does not close all the way, and the door seal is o/k, then I suggest you replace both door hinges. Please rate my solution. Thamks.
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 • Ovens
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
