Question about Dell Office Equipment & Supplies
I cannot get printer to print documents with equal margins.
How to adjust printer to print documents with equal margins. Currently it prints documents with print 2 inches from left margin and right margin runs off right edge. I know its the printer because when I send document to a Dell printer, the margins are equal.
Posted by Ed Sherman on
  • Anonymous Oct 15, 2015
    either the printer or the app to create the document was set 2 in. for the left.
    may use print preview (if possible) then adjust.
    verify the default printer settings.
    remember: all printers have minimum margins allowable.
Mister Danger
  • Dell Master
  • 5,631 Answers
Guess you are not using the same page size as the one you've got configured in your computer for printer. ie: you are using Letter and printer is configured to A4
Posted on Jul 18, 2015
When printing the document info is cut off on the left hand side op the paper
printer tiflon is damage please contact the shop kapeer and repair tefon paper
Apr 13, 2012 | Canon LBP6000 Laser Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
Bottom of page is cut off sometimes printing from vista computer
Hi- I'll try to solve this.
Go to the start menu and open the Control Panel. Double click on Printers. Right click the L7580 printer and choose "Printing Preferences" On the preferences window click on the "Advanced" tab. Make sure "Advanced Printing Features" is set to "Enabled" Under "Printer Features" turn "Minimize Margins" to "On"
This should solve the issue. If minimize margins is off, it will cut it off at the bottom.
Feb 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
E-mails won't print the last few words on the right side.
Your margins need to be adjusted. Do a print preview. You should see the margins. Click on the right hand margin and drag it over to the right until the rest of your document shows up on the screen. If you print it then it should be fine.
Nov 13, 2008 | HP PSC 1410 All-In-One InkJet Printer
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
159 people viewed this question
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
