Question about Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard
What are some reasons my tablet wont turn on?
Posted by Isabel Geraldo on
Huseyin Huseyin
  • Proscan Master
  • 3,469 Answers
Switch broken
motherboard faulty
batteries not charging
charger faulty
power socket used to charge faulty
faulty fuse in power plug
faulty processor
faulty ram
Posted on Jul 18, 2015
Testimonial: "do you have any other possible outcomes for my tablet not turning on?"
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
Dec 16, 2015 | Tablets & eReaders
Camalio tablet. Why doesn't t turn on?
The battery may have been in a discharged state for too long and will have to be replaced.
Aug 22, 2015 | Tablets & eReaders
I know how to turn on my tablet, but for some reason....it is not turning on today. I have tried the on button and also tried pressing and holding it down a couple of times and it still wont turn on. it...
try holding power button down for 20 seconds. if nothing, then tr holding power and up or down volume on bot at the same time for about 20 seconds or until something happens and release both t the same time. good luck. oh, and some tablets there is a reset hole on the bottom or side that you can reset with a paperclip.
Mar 03, 2015 | Irulu 7" 4gb Google Android 2.3...
How do I fix my toshiba tablet that wont turn on?
There are certain reasons which does not allow tablet to turn on
Maybe the connecting wire of Tablet and its PCB. I am referring this video, it might help you
Feb 16, 2015 | Toshiba Tablets & eReaders
What do i do if my tablet wont turn on and ive tried charging and hitting the reset button
If you can't just turn it on after it's been charging, you need to get it fixed or replaced.
No reason why you can't go though warranty on that, waste of money if you don't.
Jul 02, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Rca tablet will not boot
Here are some common reasons tablets wont boot:
- SD card full or corrupted
Remove SD card (if you have one in your tablet) and try to boot
- Corrupted OS / Application / Data
Try a reset
If your tablet is rooted, you can often boot with the bootloader and wipe the application data.
re-flashing the firmware of the tablet works 99% of the time.
Jan 30, 2014 | Tablets & eReaders
I turned off my tablet during an update. when it powered back on it wont fully come on. it is stuck on a screen. how do i get it to work again?
need more info ...what screen is it stuck on? what does the screen say? is it an error screen ?what update was the system doing at the time ? .... there are too many reasons why a boot process can stall at a specific time.
Nov 02, 2013 | Samsung Galaxy Tab Tablet PC
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
MY touch screen wont work for some reason so now it wont work
I suggest you to perform a hard reset as sometimes this may be due to a software glitches chances are rare though but still you can give it try. Else you need to replace the touch panel of your table which I suggest you should not do on your own rather take it to a hardware shop. Hard reset in most of the android tablets is usually performed by turning off the tab and pressing power button while holding the volume down key.
Sep 26, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard Logo
236 people viewed this question
Top Proscan Tablets & eReaders Experts
Lee Hodgson
Lee Hodgson
Ngoro
Harrie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
