Change fuse it comes on ac does not come on. unitruns then fuse will blow
Could be a short in the thermostat wiring between the air handler and outdoor unit.
Its drawing much to high amperage on startup. It may be dirty, unmantained, blocked with something, or a bad run capacitor. Likely, at this stage, it needs replacing. If its belt drive, be sure you have the proper slack and the bearings, if needed, are oiled and not faulty.
