Question about Ryobi Lithium Ion 18 Volt 18v Cordless String Trimmer Edger Weedwacker P2002
Ryobi electric hybrid weed eater quit working.
After putting the electric cord on it. It slowed way down then quit. I didn't have but a 25' cord attached. Why did this happen and what can I do to fix it.
Posted by Mandy Berrong on
My string keeps going back into and catching underneath the spool. How can I stop this?
Trimmer cord can become brittle and break off prematurely, the material can absorb water and become more flexible, so you should store any new cord in a bucket of water to keep it flexible,
May 29, 2018 | Ryobi Garden
Missing power cord to weed eater what can i use to power it up?
Most electric weed whacked use an extension cord....just plug the end into the weed eater
Oct 07, 2016 | Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed eater made a noise then just quit working, pull cord wont engage
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
I am looking for a Ryobi weed eater manual. Need to know how much oil to put in my weed eater. Can you give me an answer or where I can get a free manual. Thanks
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Sep 23, 2010 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Question about Roybi weed eater's line length.
the standard line length is around 3-4". you can leave it as long as you want, provided it does not bog the engine down, or bog down when cutting plants.
however plastic line breakage is typical of older line. it gets very brittle. Also typical of hitting rocks, gravel, cement, asphault, ground, etc.
Apr 18, 2009 | Ryobi Garden
Ryobi Lithium Ion 18 Volt 18v Cordless String Trimmer Edger Weedwacker P2002 Logo
1,140 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
bryan st
Tim Venetis
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
