Question about DeLonghi DE500P Dehumidifier
How can I remove the front cover of a Delonghi DE500P?
I've removed the two screws from the lower sides, and the two screws halfway up behind the removable bucket, but something still holds at the top. How does the front panel of the Delonghi DE500P come off?
5 Related Answers
Anonymous
  • 159 Answers
SOURCE: Dehumidier Delonghi DH400P not removing any water from the air
Only thing I can tell you to do is to make sure that the evaporator in the back is ice and cold. If the evaporator is not cold the unit will never remove moisture from the air. And if that is the case you have a sealed system problem. The unit may have a leak so there is no gas in it. The compressor may not be working or the humidstat my not be working properly. So check those thigs out or if its under warrenty call for service.
Posted on Jul 12, 2007
Anonymous
SOURCE: DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Posted on Apr 23, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Posted on Apr 25, 2010
SOURCE: i have Delonghi DE500P dehumidifier was running
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Posted on Aug 17, 2010
Cat Croitoru
  • 368 Answers
SOURCE: DeLonghi DE500p quit. Won't light
I am glad to HELP YOU!
If the light doesn't work while plugged in that means the compressor is out and it has to be replaced.
Anyway I've found for you the components HERE [the drawing can be printed and you can show it to an electrician if you will decide to fix your device...] and above the drawing, in BLUE, you have a link [called OWNER'S MANUAL] to the... manual, of course. It's downloadable in PDF format [you will need Adobe Reader to visualize it].
Or you can take the manual from HERE and the Adobe Reader from HERE.
I wish you all the best!
Posted on Apr 26, 2011
My DeLonghi DD50PSC dehumidifies but the pump never comes on. Everything is ocnnected to the continuous draiining using the pump. Suggestions?
A blocked drain tube was the cause of the pump not working issue with this dehumidifier. I removed the back cover (5 screws on back, 1 screw on each side) and cleaned out the accumulated gunk in the small, clear reservoir on the back right. It took a little time using compressed air and pipe cleaners, but the effort ultimately worked.
Jun 14, 2012 | DeLonghi DE500P Dehumidifier
Den 500p dehumidifier fan works but compressor does no activate
Phil, it may simply be a case that you have the humidity extraction level set to high. Try lowering it to 32 - 35%. If your unit is not equipped with an LED Screen, set the manual control to Maximum.
Also, remove and check the air intake filter, to see if it needs cleaning. And maintain at least a minimum of 12 - 18" of clear air space around the entire unit, while in operation.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
Need a part
This appliance has 3-ft drainage hose and a 16-ft pump hose. I searched for a store that carry these hose, unfortunately, none of them sell a part or accessory for the DE500P.
Kindly click this link and verify if they could sell a hose:
http://www.nextag.com/delonghi-de500p/compare-html
Good luck.
May 03, 2009 | DeLonghi DE500P Dehumidifier
Dehumitifier wont condense water
This happened to me after the unit was turned on after being off all winter. I've had it just two years. After speaking with "support" I gather that it needs a new condenser, perhaps just because the freon may have escaped. It may be a sealed unit. Anyway, the math works out to simply discarding it and buying a new one. For me, this means not buying a DeLonghi. By the way, their service centers are strategically placed in remote areas to attract the fewest claims HD
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
De500p lost owners book
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
May 05, 2008 | DeLonghi DE500P Dehumidifier
DeLonghi DE500P Dehumidifier Logo
271 people viewed this question
Top DeLonghi Dehumidifiers Experts
jdthefixer
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
