Question about Sharp MX-2700N Color Copier
What shall do when i encounter "finisher out of service error"
I wanted to use the machine and it is showing the above error message
Posted by zeks on
Norman J Weimar Jr
  • Sharp Master
  • 6,958 Answers
Well you could power off the machine disconnect the finsher phyiscally and electrically and then power on the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 30, 2016
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
Samsung scx6555n showing error #31-007
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Sep 13, 2012 | Samsung SAMSUNG SCX6555N LASER...
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
Panel is switching back between 6 and F at the end of the cylce
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
Above is a link for the error codes and what they mean.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is your service and repair manual. with troubleshooting steps, to isolate your issue.
Jun 22, 2010 | Kenmore HE2 Plus Front Load Washer
Microsoft office has encountered setup contoller error
the best thing "try to reinstall ms office" because of "a problem during install", and while installing new one make sure of "customized install" process. Again if you got the same, try to use "specify" the log file "error message", I do wait for your reply.. have fine
Dec 15, 2009 | Microsoft Office PowerPoint Home and...
GENERIC HOST PROCESS FOR WIN32 SERVICES HAS ENCOUNTERED A PROBLEM
I guess it is a network virus! Repair your os, or reinstall it if needed , and do not share anymore or buy a Total Security antivirus!
Nov 16, 2008 | Microsoft Windows XP Media Center Edition...
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Sharp MX-2700N Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
