The pet power brush does not spin. I closed the suction valve and check for blockages.The pet power brush does not spin. I closed the suction valve and check for blockages.
You can't post conmments that contain an email address.
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
i would change the bag and under the bag there is a filter, if dirty wash and make sure its completly dry before putting back into machine. once all done, have machine in upright position, turn on and see if there's sucktion at hose. hope this helps
Please unscrew the hose connection to the back panel. Is there suction there while in the upright locked position? If so, visually check the hose inside for obstructions.
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
According to the manual on your machine, you can either have a broken belt, or the switches to the self-propel switch, and brush switch are in the off position. I have included a link to your manual. Please look at pages 13-14 under troubleshooting.
you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
