Question about Health & Beauty
His I've a victory xl mobility scooter and constantly red flashing on battery meter and don't charge battery's properly can u help cheers
Posted by Mark on
Huseyin Huseyin
  • 3,469 Answers
Hi, at a guess I would say that your batteries possibly no longer hold a charge. If the scooter has been provided for you get the organisation who gave it to you to check it over, they should service it for you.
There is a link below for the website that provides an owners manual, this may help you troubleshoot the problem
If you need anything else please post another query.
Pride Mobility Victory XL 4 Owner Manual
http://www.manualslib.com/manual/718600/Pride-Mobility-Victory-Xl-4.html
Posted on Jul 17, 2015
5 Related Answers
gewiz
Rob Hill
  • 1414 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
my-mobility
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
oregoon
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
Jun 15, 2015 | Pride New Mobility Victory XL 4 Wheel...
Hi what fuse does the victory pride xl take plz
hi ,where is the fuse you referring to lcoated , the battery one or the one located on the tiller stem ?
Regards
Rob
www.gewizrepairs.co.uk
May 23, 2014 | Pride New Mobility Victory XL 4 Wheel...
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Blue light on battery condition meter is blinking. It doesn't stop.
hi the blue light is indicating a fault, now count the flashes before a pause, or does it just flash all of the time ?
Please keep me updated.
Regards
Dec 22, 2012 | Pride Pursuit Xl Heavy Duty 4-wheel...
Set to move at 8 mph on full charge speed set to max only moving at 1 mph or less using battery charge in 20 mins
Hi, Sadly that sounds like your batteries have called it a day however please check your charger as this can have a fault and this can make your batteries appear weak and the battery teminal connections, are they loose ?. Check your manual as I think you can fit 12V 40Amp batteries to this scooter.
Please leave feedback if my advice helps.
Jan 17, 2011 | Pride New Mobility Victory XL 4 Wheel...
Wont hold a charge. Batteries checked out ok. Could it be a short? Is this common?
If the batteries have been volt tested OK and they wont hold a charge, check your charger to make sure it is functioning properly. If there was a short, the scooter most likely would not work or would give a flashing light code. Batteries typically will not hold a charge when they are damaged, have been sitting unused for a while or if there is a mechanical issue that is causing dtrain on the motors. Check the air pressure, bearings and ensure there is no noise or vibration that may indicate a motor failure. If all those check OK, replace the batteries.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
We put new batteries in it. We had them tested so
Hi. Have you checked the free-wheel lever is in the correct position?
Is one of the battery lights or any LED flashing? If so, count the flashes between the pauses, and let us know.
E mail at [email protected]
Good luck. Neil.
Jul 23, 2010 | Pride New Mobility Victory XL 4 Wheel...
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
150 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
