Question about Electrolux Dishwashers
My Electrolux dishwasher ES167070xr is showing fault code i30 -anti flood. How can I fix it?
Posted by Tegwen Green on
  • Electrolux Master
  • 18,665 Answers
There is a sensor under that unit that detects water. IF there is a leak in the tub, it shuts off. Take the front kick panel off and look to see if there is any water under that machine or in the pan. If so dry it out and run it and see where it is coming from.
Posted on Jul 16, 2015
Error code i30 (leak). How to fix it?
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
Dec 13, 2015 | Electrolux Dishwashers
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
The anti-flood system has been triggered on ELECTROLUX ESF 656 how can I fix it?
The anti-flood system has been triggered means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
Dado
Jul 22, 2014 | Electrolux Dishwashers
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
How to fix code i30
Dado
Jun 01, 2014 | AEG 23 in. Favorit 86070Vi Built-In...
My dishwasher keeps flashing i30 and wont start what shall i do
In your case occurred intervention of anti-flooding system.
Displayed Error is "i30"
The cycle is interrupted and the drain pump switches on.
Could be:
Water leakage from the tub - sump and various
connections (pump, upper spray arm duct etc.);
floating sensor blocked mechanically; microswitch
faulty; fill solenoid blocked mechanically; circuit
board faulty (solenoid triac short-circuited); wiring
faulty.
First, try to tilt dishwasher and see if leaking water from its bottom.
This is most commonly occurs.
Dado
Jan 20, 2014 | Electrolux Genuine ZANUSSI ZDF511...
I30 error code electrolux
my dishwasher is show AL7 and stop working
Sep 23, 2013 | Zanussi 24 in. DE6965 Built-in Dishwasher
Error code i30 what is it
Dado
Apr 07, 2011 | AEG 24 in. Favorit 80860iW Built-in...
Hi. I'm getting an i30 message on my dishwasher. This is an anti-flooding protection.How do I reset it? The waste filter was a bit blocked, it's all clean now. Cheers
depends on the model. some have a float switch in the base just removing the water from the base will reset it. othr models have alock out valve removing water pressure from the water valve can reset it. although blockages in a side tank lh side can be more complicated.you say its electrolux. aeg have a similar problem where a thin hose from the sump to pressure switch sags . tie up the pipe fixes it.
Aug 06, 2010 | Electrolux Dishwashers
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
