Question about Fujifilm FinePix F660EXR 16MP EXR CMOS Digital Camera B... [16227480]
How do i remove lens,to check & possibly replace lens cover.
Posted by sid_jones95559 on
james laughton
  • Fuji Master
  • 2,195 Answers
By carefully dismantling the camera
Take a look at YouTube to see how to dismantle compact cameras and decide if you are happy to give it a go
Posted on Jul 17, 2015
Can't remove lens cover on rear to access burned out bulb. Screws are out but don't want to crack the cover.
it may be possible that you don't have to remove the lens cover to replace the bulb, in most modern vehicles the bulbs come out from inside the trunk by turning the fitting & pulling the bulb out & replace it the same way by putting it back in & turning it in the opposite direction to lock it in place.......hope this helps......cheers.
Sep 04, 2011 | 2002 Mazda Tribute
Hi, my camere picture is getting unclear. Is it possible to clean the lens or change the lens cover. Or do you have other solution to my problem. The camera is 6 years old Regards Preben Keim
Remove the lens cover and see if the picture gets clear, if so the camera has gone weak and it is better to get the latest higher resolution type. However if this is clearer then you can clean the lens using lens cleaning solution and then change the lens cover.
Jul 07, 2011 | Toshiba IKWB15A Network Camera
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
Have a acer 4730Z and the lens cover on screen frame is scratched. can the screen frame be removed to replace cam cover...crystal lite
No this is not possible to remove an replace the screen frame only. you have to replace complete screen in service center.
Regards
Ashly
Feb 02, 2010 | Acer Computers & Internet
E4 54037380 Cannot record to disc?
This seems to be a common problem on all DVD players
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Nov 07, 2008 | Televison & Video
Olympus Stylus 600/Digital 600 6.0 megapixel
Hi
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Recording Disk Problem Cannot Record On This Disk E4 54037380
This seems to be a common problem on DVD recorders.
You will need:
should do.)
8. Replace Lid
Aug 22, 2008 | Televison & Video
When i try to record it comes up error e4 54037380 toshiba d-vr16sb
This seems to be a very common problem with DVD recorders.
You will need:
should do.)
8. Replace Lid
Aug 03, 2008 | Televison & Video
No startup on lens cover opening
well the problem it´s on the switch that turns on the camera that is located under the lens cover.... this swith is glued to the front cover and lots of times gets unglued, u need to remove the lens cover by removing 2 screws on the bottom part of the lens cover, after that just pull the switch slowly and glue it. don´t use 3 seconds glue use a more viscose one. good luck
Feb 14, 2007 | Olympus Stylus 400 Digital Camera
Fujifilm FinePix F660EXR 16MP EXR CMOS Digital Camera B... [16227480] Logo
114 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
