I assume as you mention travel trailor, that you are talking about removing internal walls of a caravan, if this is correct, personally I would not advise removing any walls if you intend to continue to tow this. Basically removing the internal walls will in turn weaken the structure of the whole unit, making this unstable when towing and as these are notorious for getting tipped over in very windy weather, it would put you and your family any a very bad position.
If it is not a caravan but a fixed property, I would advise contacting an architect or even a local builder for advice.
Hope this helps
You can remove any walls that you want provided that they are not load bearing. You would need to cut in and place Akro props before removing structural. walls.
SOURCE: window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
